Currently the area command cleans up to the outside of a wall. How can I change to outside of a stud?
Version(s): 10, 11
Select File > Drawing Options > Material Dimensions > Material Options. The area’s cleanup location is linked to the structural slab locate. By selecting “Bearing” the area will find the bearing material in the wall of that plan, which on an exterior wood framed wall would be the stud.
Version(s): 12 +
Once the area is drawn it can be edited. In the properties it can be changed to Exterior Edge, Outside Bearing Edge or Interior Edge. Then a Cleanup will set it into the correct place along the walls.
Posted in Area: FAQs, FAQ.
Leave a Reply
Your email address will not be published. Required fields are marked *
You may use these HTML tags and attributes: <a href="" title=""> <abbr title=""> <acronym title=""> <b> <blockquote cite=""> <cite> <code> <del datetime=""> <em> <i> <q cite=""> <strike> <strong>
This blog is kept spam free by WP-SpamFree.
