SoftPlan 2016 New Features: Plan Sets
Building Options
Multiple Building Options can be displayed on a single plan set. Used to show a plan with one option included and the alternate options on the side of the same sheet.
Crop View
Crop View command added to the right mouse click.
Draw Select
Draw Select command added to Plan Sets. Available on the toolbar.
Erase
Erase (drawing or view) command added to right mouse click.
Drawing Schedule | Table of Contents
Drawing Schedule or Table of Contents command added.
Export
DWG and DXF Export added to Plan Set Pages.
Rotated drawings Export improved.
Fonts
Font Options added for Drawing Name and Drawing Scale.
plan_set_2016_rev2016_plan_set_label_setup
Groups
Prefix added to Groups, used in place of the group name when numbering pages. For Example sheets in the Architectural Group may be numbered Arch-7 or A-7.
2016_plan_set_groups
Import
Image Import added.
plan_set_2016_rev
Label
Automatic Labels showing Drawing Name and Scale are added to the Plan Set when a drawing or view is added.
2016_plan_set_label
Missing Drawings
Notification added when drawing previously included in a Plan Set cannot be located.
Individual pages and page ranges can be sent to the printer.
2016_plan_set_print
Print added to the toolbar.
2016_plan_print_toolbar
Regenerate
Edit 3D Views—Regenerate added to right click.
2016_plan_set_3D_regenerate
Rename
Rename Plan Set added to the right mouse button.
Revision Schedule
A Revision Schedule can be added to the Plan Set listing all the Revisions for the Project.
Template
Plan Set Templates added.
This command allows you to quickly and easily reuse an arrangement of drawings, details and views on a different project.
2016_plan_set_templates
12 Comments
    • You may want to double check with support but I think the date format is set in your computer not within SoftPlan.
  1. Is there a way to change the pen thickness for the watermark? I have tried a few things but haven’t had any luck
  2. So with multiple building options within a plan set will we be able to have a base floor plan but have cut sheets showing different options (add on rooms) that could show on one sheet but not another? Please say yes!
  3. Can we show the different positions for exterior doors – outswing doors the door would be at the front of the jamb and interior swing doors at back of jamb. Correct positioning of the exterior trim to show at 1/2″ or 1/4″ reveal instead of the jamb thickness.
  4. No place to comment in openings. So will add it here.
    The ability to be able to show interior framing as one color and exterior framing as another color. Now if you make your interior jambs oak then exterior door and window jambs are the same color which in reality is not the way it works.
  5. Yes! The template feature may be the biggest time-saver being implemented into 2014 yet! It gets tiring after several hundred projects to create and modify the exact same plan set scheme.
