SoftPlan 2018 New Features: Openings
Auto Join Openings into Units
Auto Join Openings into Units option added, when this is turned off two openings in close proximity to each other will NOT join together but remain independent.
2018_Opening_Auto_Join_Opening_Option
Cottage Windows
A Cottage Window library has been added to the standard opening libraries.
2018_opening_cottage
Deflection
Deflection option added to quickly change a   window to an arch top now applies to 2 section windows.
2018_Opening_Deflection
Dimension
Dimension option “Width” added; displays width only.
2018_Opening_window_width_only
Elevations
Direction arrows illustrating operation added to saved Elevations and Sections.
Display Hinge Side illustrating operation added to saved Elevations and Sections.
2018_Opening_window_direction
Frame Material
Frame material can be a different color on the inside of the opening vs. the outside.
Gable Ends
Grilles added to Windows in Gable Ends.
Shutters added to Windows in Gable Ends.
Pediment Trim added to Openings in a Gable Roof End.
2018_Opening_Gable_Ends
Grille
Repeat Edit ability added for Grilles on Elevation Openings.
Starburst Grille option added to Round Top Openings.
Sunburst Grille option added to Round Top Openings.
2018_Opening_Grill_Sunburst_StarBurst
Opening Schedules
Glazing Area added to Opening Schedules.
Header Position added to Schedules.
2018_Opening_Schedule
Open in 3D
Open / Close Opening command added to Right Click menu in 3D.
2018_Open_3D
Pocket Doors
Pocket Doors extension from center of the hole in the wall rather than the center of the entire unit.
Pocket Doors — a reversed Pocket Door will no longer show as “modified” on the Opening Schedule
2018_pocket_extension
Sliding Barn Doors
New opening type Sliding Barn Door Type added.
2018_opening_sliding_barn_door_revised
Threshold
Threshold displays in 3D.
Hide Threshold now renamed to Show Wall/Sill Lines.
2018_opening_threshold
Trim
Trim option Stop at Transition added; prevents door trim from extending over lower portion of wainscot wall.
2018_Opening_Trim_Transition
Trim option Stop at Wall Bottom added;  prevents door trim from extending over foundation wall.
2018_Opening_Trim_Foundation
Trim separated into different material types for wood, vinyl, cast and stucco.
Stucco added to Exterior Trim types.
2018_Opening_Trim_Type
12 Comments
  1. just wanting to know if there is going to be a superior walls foundation basement added to the wall section
    of the walls created?
  2. When finishing walls in basement, and studs and drywall are added in front of Block or concrete wall, that creates a
    new wall thickness, anyway to adjust the depth of the opening for doors and windows?
  3. can screen doors be added to door openings in the same way you can with grilles or other components where that the screen swings out as dotted line?
  4. Glad to see glazing added to the schedule. This will help with light amd vent schedules for the rooms in the house. Is there also one for clear opening area as this is also part of the light and vent schedule?
  5. Great job on these! Looking forward to more flexibility with openings in a gable end, being able to have different color frames on openings from the exterior to interior (we do mostly clad exterior/wood interior in this area so this is wonderful!). The arrow showing the direction is great (always drew that in separate) as is the addition of the barn doors (had to make my own due to demand for them). Way to go guys and gals!!!
  6. Really looking forward to these improvements. I think I’ve personally had to do work arounds with almost all of these items…mostly with 3D solids. Definitely going to save some time.
  7. I like the added new features of the openings. I do have a question about sliding barn doors, are they stationary or do they act like a regular door where you can adjust the features like how much to show open or add molding and edit like a real door opening?
    Thank you for answering my question.
    Dominic
