SoftPlan 2018 New Features: Stairs
Break
Height option added to control how much Stair is shown before the break happens.
Hide Lines option added to remove the lines above the Break.
2018_Stair_Break_2
Landings
Finish options added to Landings.
Library
U Shaped stair library added.
2018_Stair_Ushaped_library
Move
Align to Edge tool can be used to move a Railing to the side of a Stair.
Newel
Newel Post extends above the Railing at turns by default.
Treads
Nosing Depth option added.
Treads on a stair with a closed Stringer extract at the correct length.
2018_Stair_Nosing
3 Comments
  1. much of the design work from our office are high end and more stair custom abilities are needed, as are roofs. Glad to see improvements and hope more will follow
  2. It would be really great if the railing that is hosted on the stairs would be hidden above the break as well when the stairs is. Otherwise I find there are always 2 railings on top of each other.
