Opening Trim – 3D Extraction
Changes have been made to ensure that opening trim extracts correctly on all specialty windows.
Changes have been made to ensure that trim (interior and exterior) extracts correctly on all triangular windows.
Fit To Roof – False Gable
Changes have been made to ensure that the Fit To Roof command works correctly on walls under false gables.
Openings – Exterior Trim
Changes have been made to ensure that rowlock trim extracts correctly on roundtop openings and other specialty openings.
DWG Import – Layers
Changes have been made to ensure that Unicode characters contained in a DWG layer that is being imported into SoftPlan will import properly.
Does the Glass Shower Wall + Tile Curb need to be downloaded or is supposed to be found with the rest of the walls? Is there a way to search for where it is?
Hello Tom,
I think the answer can be found on the forums. From what I recall I think it comes supplied with the walls when you do an update to 4.4.
I hope this helps you,
Dominic
