SoftPlan Mononpoly House SoftPlan Home Design Software
Can I add my custom walls from an older version without recreating them?
Yes. This is done by performing a Backup and Restore. In the older version select File > System Options > Archive > Backup > Select your target Drive. Open the newer version and select File > System Options > Archive > Restore > Configuration. Close SoftPlan and restart SoftPlan again. This will restore all settings under File > System Options in the newer version (Material Dimensions, Wall and Beam Definitions, etc…). If desired, Wall Type or Beam Type can be selected to restore the specific items.
