How do I add custom grilles, like prairie style grilles to an opening?
Version(s): 10
The grilles need to be drawn on the Elevation Opening. Draw the desired Elevation opening from Draw > Detail.
Draw the grille pattern with lines (Draw > Shape > Line). Add the Elevation Opening as a new Opening. Refer
to the Learning SoftPlan manual regarding how to add new openings.
Version(s): 11 +
The grilles need to be drawn on the Elevation Opening. Draw the desired Elevation Opening or Opening Shape from
Draw > Detail. Draw the grille pattern with lines (Draw > Shape > Line). Save the Elevation Opening into
the System Library as a new symbol. Refer to the Learning SoftPlan manual regarding how to add Elevation Openings.
Once it is added, add a new Opening in the System Library. Then link the Elevation Opening symbol you created to
it. Refer to the manual on how to add new Openings.
