What are the optimum settings for plotting text using an older style pen plotter?
For clarity, as well as speed, set up to use the Font Style SPSIMP with a size of 12. Then from File > System
Options > Character Setup > remove the checkmark on Fill Fonts Solid > Pen Plotting. The pen thickness to
use will be a 0.35mm, which is just wide enough to fill in the fonts as it traces the outline of each
character.
As an alternative choice, you may also set up to use the SPEVAN font and assign a size of 11. This will give more
of a hand style font.
