I am currently designing a house that has some barn style to it and would like to add a widows peak to several gables.
Any ideas on how to do this??
Thanks!
Posted 11 February 2016 - 11:41 AM
Pull the gable out from the face of the wall as far as you need to the front of the widows peak and then use a hole (you can draw it as one continuous hole - even though it looks like two) to cut away what you don't need.
Although you will have to turn off the soffit and create it with a ceiling, and you'll still get an odd detail where the fascia's meet, as Softplan will only cut the fascia square.
Posted 12 February 2016 - 12:06 PM
for a simple widows peak as keith shows,
cutting out the unwanted roof is definitely
the easiest way to go,
you can also put in beams to get the same widows peak.
or
you can put in beams for the roof to follow at the gable
and get some different design / style
such as the widows BEAK at the far right
note, when using the 2 beams, notice that the ridge will be sloped
instead of a level ridge like Keith's method of drawing a regular square end
and cutting the hole at the angles.
note: roofs are always the most difficult to learn in softplan.
best to practice each time you read threads such as this one
so it'll be easy when you have a similar roof style.
don't forget the use of beams along with the walls.
left click to "enlarge" image below
v10 to future 2016+
