Change Door Window Insert Size
openings Door inserts edit openings
#1 Verlin Klassen
Verlin Klassen
  • 263 posts
  • LocationBirnie, Manitoba, Canada
Posted 17 February 2016 - 03:32 PM
I am trying to add an exterior door with a sidelight to my drawing with a 48" long window in the door and the sidelight. I have a similar door in my openings library, but the window inserts are only 36" long. What is the best way to create a door with the windows I need?
Verlin Klassen
Westman Drafting
  • 5,098 posts
Posted 17 February 2016 - 07:47 PM
Draw it ...
Have a look at this thread ... http://softplan.com/...-entrance-doors
I'm not at a Softplan computer at the moment, but basically, draw the door frame, draw the glazed insert, and add all the detail you wish with lines and arcs.
Use the same procedure as the custom garage door here ... http://softplan.com/...pening-tutorial
If anything is still unclear, post a picture of the door, and I'll do a step by step tutorial.
#3 Yvon Gonthier
Posted 18 February 2016 - 07:17 AM
Also, if it's the same but just the height of the glazed panel and panels underneath that are different, you can take the original elevation opening, explode it and adjust the heights as required and save as a new elevation opening.
#4 Verlin Klassen
Verlin Klassen
  • 263 posts
Posted 18 February 2016 - 09:37 AM
Got it. Thank-you very much.
Verlin Klassen
Westman Drafting
Also tagged with one or more of these keywords: openings, Door inserts, edit openings
