graphical artefact
#1 Stefan Liede
Stefan Liede
  • Validating
  • 70 posts
  • LocationBC, Canada
Posted 18 February 2016 - 11:30 AM
after creating the site model
i got in 3D and elevation mode
this odd plane partially above the foundation
it is also visible inside the building when i put
the next storey on top
please help
thanks in advance
-stefan
#2 Yvon Gonthier
Posted 18 February 2016 - 11:37 AM
Do you have a building outline to cut thru the site? If yes, is it adjusted properly to the foundation?
Posted 18 February 2016 - 01:07 PM
Go to Visible Items and check Display Everything and see if you can identify it there.
#4 Stefan Liede
Stefan Liede
  • Validating
  • 70 posts
Posted 19 February 2016 - 06:08 AM
Yvon, thanks, that was the solution
in site mode i had to create a new building outline
because the basement walls with footing did not
extend deep enough into the steep sloping of the property
so i had to add an additional foundation
to the existing building
removing the old basement in site mode and merging the
new one with "GENERATE BUILDING OUTLINE" from the foundation plan
solved the problem
the odd artefacts have disappeared
