Symbols
11 replies to this topic
#1 Guest_Raymond Smith_*
Posted 10 February 2015 - 03:38 PM
I'm using 20 fourteen.  In my system library, some symbols are shown with a black background.  I can't see what the symbol is.  How do I change it?
#2 Thomas Roman
Thomas Roman
  • 341 posts
  • LocationSacramento, CA
Posted 10 February 2015 - 06:58 PM
hmmm.... in the DRAWING OPTIONS / ASSIGN COLORS menu there is a check mark to assign the color of the paint within a symbol...
that's all I got....
#3 randolph cohn
Posted 11 February 2015 - 11:32 AM
if toms suggestion doesn't work >
try this:
in your drawing > at the very top
go to / options / and at the far right column,
there is "paint in symbols"
if it's checked    /    UNcheck it
#4 Chris Stewart
Chris Stewart
  • Banned
  • 238 posts
  • LocationTexas
Posted 11 February 2015 - 11:56 AM
I think he is talking about his library window and not the actual symbols on the plan.
Most likely trying to select a new texture within SoftView where many plants in particular are on a black background.
If this is the case than I suppose that you could try turning up the brightness and contrast of your monitor.
-Chris
#5 AJ Spino
AJ Spino
  • 91 posts
Posted 24 May 2015 - 08:51 AM
try this:
Randy, I don't see "paint in symbols" under options...I'm using 2016, does this only apply to 2014?
I'm experiencing the same problem, but I noticed it's not doing it on all the drawings in my project.  My system and drawing options are set the same across the board, but the main floor is printing some of the symbols solid black (notice the clothes hangers are fine).  I also noticed the beams are filled with a color instead of just dashed lines.  I tried to edit them in define beams, but I couldn't find anything to change that would get them back to dashed lines.
Any suggestions?
#6 Martin Livingston
  • 693 posts
Posted 02 June 2015 - 02:57 PM
I created a lot of symbols and had the same issue. It only affects the thumbnail view of the symbol in the symbol selection window. In the various schedules the appear normally. It hasn't been a problem yet so I haven't looked for a solution.
Posted 02 June 2015 - 06:21 PM
See this post for more explanation.
#8 randolph cohn
Posted 03 June 2015 - 11:54 AM
could someone let us all know what the correct answer to this question is when it's figured out ?
i don't understand what your trying to accomplish.
#9 D M
D M
  • 402 posts
  • Location..
Posted 04 June 2015 - 10:34 AM
42
#10 Keith Almond
Posted 04 June 2015 - 02:58 PM
Thank You Ford.
#11 randolph cohn
Posted 04 June 2015 - 04:45 PM
do you guys have your own codes ?
what does 42 represent ?
and who's ford ?
  • Yvon Gonthier likes this
#12 D M
D M
  • 402 posts
  • Location..
Posted 05 June 2015 - 07:08 AM
Hitchhiker's Guide to the Galaxy
