Importing DWG
importing dwg dwg
7 replies to this topic
#1 Jason Fischer
Jason Fischer
  • 15 posts
  • LocationGranger, Indiana
Posted 17 March 2016 - 02:24 PM
I'm having an issue importing a DWG file (a site plan from an engineer) - when it imports, it is not to scale.  I'm assuming it is not a softplan issue and maybe something with the DWG but wanted to check if anyone has run into this.
#2 Rick Kingsbury
Rick Kingsbury
  • 104 posts
  • LocationSpearfish, SD
Posted 17 March 2016 - 03:24 PM
If I remember correctly you have to scale it x12.
  • Jason Fischer likes this
  • 4,198 posts
Posted 17 March 2016 - 08:47 PM
Maybe even more than that. As far as I remember, in Autocad, you set a scale, and Softplan is actual size. So if the AutoCad Site Plan drawing is 1:200 then you would multiply it by 200 to get it to 1:1 etc.
#4 Yvon Gonthier
Posted 18 March 2016 - 06:27 AM
I've had both cases that I received them and had nothing to do and other times have to adjust. Depends on the set-up from the original sender.
I always use the "Adjust Size" function with the snap activated and select a distance on a line I know the dimension of and that works pretty well.
  • 4,198 posts
Posted 18 March 2016 - 06:47 AM
When you say "Not to Scale", I assume you mean not to a recognizable scale? Once you find out the multiplier it should be correct. As Yvon said, find the biggest known dimension you can, and use adjust size.
#6 Martin Livingston
  • 631 posts
Posted 19 March 2016 - 06:03 PM
If the DWG drawing units are set to "architectural - inches" it should come in scaled correctly every time. Unless of course your Softplan drawings are in metric..
#7 Fred Russell
Fred Russell
  • 167 posts
Posted 20 March 2016 - 12:18 PM
A surveyor sent me one not to scale and when I called he said he would send it at a 40 scale, which worked out correct
#8 Jason Fischer
Jason Fischer
  • 15 posts
Posted 23 March 2016 - 04:56 PM
Thanks - it worked at a x12 scale.
  • Rick Kingsbury likes this
Also tagged with one or more of these keywords: importing dwg, dwg
