Double tapping "Escape"
#1 Martin Livingston
  • 703 posts
Posted 28 June 2016 - 02:39 PM
Hi.
Has anyone else run into a little bug with the software that causes the program to shut down instantly, without warning and without saving anything from the current session (other that the normal autosave function)? It has happened to me on several occasions if I accidentally tap the escape key twice or more which is a reflex carried over from years of drawing with Autocad. The application just disappears as if you opened the task manager and shut it down there.
Softplan support said they cannot duplicate it and suggested I check my PC setting. I can't find anything that would cause this and it only happens with Softplan.
Any ideas?
Cheers!
  • 5,301 posts
Posted 28 June 2016 - 02:49 PM
I've had Softplan shut down unexpectedly for no reason, with no warnings, but couldn't figure out what I'd done. It's very possible that I may have done the same thing. Although I cannot deliberately recreate it!
#3 Martin Livingston
  • 703 posts
Posted 28 June 2016 - 03:31 PM
I tried to deliberately do it as well with no luck. It happens so fast I can't tell the exact key sequence. All I can really be sure of is that each time I am trying to back out of a command in process "AutoCAD style" by tapping the escape key a few times.
#4 Martin Livingston
  • 703 posts
Posted 29 June 2016 - 04:59 AM
I did a few Google searches for "double tap escape" and similar phrases . Double tapping escape seems to be a shortcut for a quick exit from some games.
#5 Matthew Schauman
Matthew Schauman
  • 25 posts
Posted 05 July 2016 - 06:04 AM
I have the same issue ( no warning and just shuts down) but can't figure out what key combo is making it shut down.
Martin Wrobel
Freeland, MI
Surface Pro 3
Softplan Version 2016
Visual Cadd
Strucalc 9.0
Sketchup Pro 2015
  • 5,301 posts
Posted 18 May 2018 - 03:02 PM
This is still an issue for me ... it happens reasonably often, but no matter how I try, I cannot deliberately recreate it ...
Is anyone else STILL seeing this issue.
#7 D M
D M
  • 402 posts
  • Location..
Posted 18 May 2018 - 03:56 PM
