How do you get a boxed out window look like the window on the upper left side of the attached pic ?
Posted 18 July 2016 - 10:08 AM
Exactly as they would construct it. Use 2" x 6" walls around it. That way you can reference floor and roof to the correct locations too.
Posted 18 July 2016 - 02:03 PM
Some Basic Steps, .. but not tuned for fine detail representation
.. but it will give you some ideas for approaching the model
Use an Opening Arch, .. Blank will work, .. size and position
both horizontally and vertically in your Main Exterior Wall
and to suit your 'box out'
Create Exterior Walls to make up the ‘Box Window’, .. offset up as required
(this example uses a different 2x6 wall type so the finish can be different than the Main Exterior)
Insert style of window desired.
Minimize Wall Joint Tolerances
Move ‘Box Walls’ into place against Main Exterior
You can try experimenting with a ‘Floor System’, .. maybe on another level, ..
.. that way you can cover floor with exterior finish, .. if that’s your preference.
I’ve added a solid as a base for the Boxed Window, positioned as I need it and match my colours.
Add Roof to suit
