Wall Purlins (Pole Barn)
16 replies to this topic
#1 Tim Booth
Tim Booth
  • 31 posts
  • LocationMissouri
Posted 18 July 2016 - 01:14 PM
I see a check box for purlins on a roof but I have searched for a way to make them on walls.  Pole Barn for example.  The only way I have figured out to do it so far is to create a "plate" wall and use the move command to attach it to the outside of the 6x6 at the bottom.  I go into the copy menu and create 5-6 copies that randomly space away from the wall, give them offsets in 2' increments.   Then I go into 3D mode and use the move command to set them against the 6x6.  Now I don't see how I get softplan to attach siding to this, so there must be a better way.
Posted 18 July 2016 - 02:16 PM
Design the wall from scratch and make the actual definition suit the construction (so 2" x 6" horizontal and typically vertical siding). The only downside with that is that each definition has to be tailored to a specific height, as adjusting the height will not automatically stretch the relevant materials.
#3 Guest_Derrik Bauer_*
Posted 18 July 2016 - 03:23 PM
I created this wall for just this reason:
Same wall, any height you want.
Here is a screenshot of the profile I created to get the purlins (nailers is what we call them) to show up:
  • Ben Ginther, Keith Almond and David Zawadzki like this
Posted 18 July 2016 - 08:07 PM
Hadn't thought about a profile, but thinking about it, that solves all the issues. Brilliant idea Derrik.
EDIT: Hadn't realised that the Pole Barn Girts are a standard profile either ...
#5 Steve and Carla Farnam
  • 680 posts
Posted 18 July 2016 - 10:11 PM
Tim,
New training video on Softplan+ that walks through Pole Barn construction.
One section takes step by step the creation of pole barn wall definition.
Posted 19 July 2016 - 06:42 AM
Had a look at the Pole barn video. That's the way I created mine, although not sure why the airspace was added. However, I prefer Derrik's profile solution. I must experiment with that.
Posted 19 July 2016 - 08:48 AM
Perfect .... Thanks Derrik. In my opinion works much easier than Softplan's solution for ease of construction and 3D, and variable heights work well too. However, I don't know how it affects the Softlist, but I don't use it ... I went with 2" x 6" girts.
#8 Tim Booth
Tim Booth
  • 31 posts
  • LocationMissouri
Posted 22 July 2016 - 07:02 AM
I am working on learning to define walls, could you show what widths you made each item and did you change any of the default values above your 2nd screenshot?
#9 Guest_Derrik Bauer_*
Posted 22 July 2016 - 03:42 PM
I honestly don't remember what was standard, and what I created.  I was thinking I created the 2x4 @16" OC profile, but I could be mistaken. Here is a screen shot of the widths of the wall:
Does this help?
#10 randolph cohn
Posted 29 September 2016 - 05:17 PM
finally got it to work.
I agree, it's in the "PROFILE" creation.
toughest wall I ever had to figure out.
and i'm good with defining walls.
btw,
couldn't of done it without  your help.
thanks to all for contributing.
hope I never have to design one for real.
#11 John Atchley
John Atchley
  • 131 posts
  • LocationNW CT
Posted 17 March 2018 - 09:42 AM
I can build the wall but cant figure out how to get the nailers/purlins to repeat 16oc
#12 John Atchley
John Atchley
  • 131 posts
  • LocationNW CT
Posted 17 March 2018 - 09:46 AM
And how would I add a vertical 1x2 furring strip that repeats 16oc. Working inside out the wall is meant to have sheathing, vertical 1x3, horizontal 2x3, vertical 1x6 siding, So that sheet of 3/4 in the previous image is meant to be 1x3 vertical. not a sheet of 3/4
#13 John Atchley
John Atchley
  • 131 posts
  • LocationNW CT
Posted 17 March 2018 - 10:01 AM
OK. I got the 1x3 vertical added. Now just need the horizontals to show every 16 instead of just one at the bottom
#14 John Atchley
John Atchley
  • 131 posts
  • LocationNW CT
Posted 17 March 2018 - 10:50 AM
Got it.
#15 Keith Almond
Posted 17 March 2018 - 10:54 AM
John, I think the key is getting the height of the furring wood correct. Since it has a profile it can be full height.
Mine  has a 2" x 10" at the bottom, 2" x 6" at 16" o.c. and a finish 2" x 6" at the top.
EDIT: You replied whilst I was typing ...
#16 John Atchley
John Atchley
  • 131 posts
  • LocationNW CT
Posted 17 March 2018 - 11:13 AM
Yes. The problem was not making it full height. I looked at the previous postings and found it. Thx
#17 Daniel Zanoli
Daniel Zanoli
  • 228 posts
  • LocationNorthern Michigan
Posted 17 March 2018 - 07:24 PM
It would be nice if we could change the roof purlins to a 2x4 like the wall I built.  This is how we do it here in N. Mich.  Note how you start your first two post for proper truss layout. 7'-9 1/2"  Then go to 8' o.c.Framing.jpg Attached File  Wall Detail.pdf   69.2KB   94 downloads
