When I edit first floor wall to fit to roof in 3-d mode my second floor walls Jump to a higher elevation. I've tried un-checking cleanup and anchor but doesn't help.
Wall jumps
Posted 08 October 2016 - 02:05 PM
check to see where your reference points light up with. you might have a taller wall on the first floor and your point on the second floor is using that as a reference.
Posted 08 October 2016 - 06:17 PM
verify. they are stacked correctly in the assembly
#5
Posted 08 October 2016 - 06:38 PM
I used to have this problem happen a lot. Randy gave me a solution years ago that has always solved the problem. Erase all your reference points, assuming you already have them. Place new reference point on the LOWEST floor in your assembly...probably the basement or foundation? Then "Copy to softplan clipboard" and draw a box around the reference point. Go to the other floors in your assembly and "Paste From Softplan Clipboard" and "HOLD POSITION. That will not only put the reference point where its supposed to be, but it will keep the floors above from moving up like you are describing. Should work...I still have to use that trick regularly.
Sam
- Tom Rogers and Bradley Schull like this
#6
Posted 08 October 2016 - 08:38 PM
Has to be the CIRCULAR REFERENCE, all the others (as far as I'm aware) work for location, but NOT height.
All CIRCULAR REFERENCE POINTS will STACK vertically on top of the highest point AT THE REFERENCE.
You may also find that a staircase or similar object is pushing your second floor walls higher than they should if you aren't using the circular reference.
Posted 26 March 2017 - 05:17 PM
as sam mentions above, start putting the ref pts (circular w/ crosshairs) on the lowest floor AND the lowest wall on that floor.
and as long as the floor above are done correctly, they'll fit perfectly into the floor below them.
tip: try not to have a NEGATIVE offset on any walls. on any floor plan.
START the lowest wall on each plan at 0.00" and go UP from there as required
by your floor levels.
v10 to future 2016+
