import pdf problem
import pdf softplan review
#1 Thomas Davis
Thomas Davis
  • 309 posts
Posted 06 January 2015 - 11:17 AM
I am trying to assemble a Huber Woods detail sheet with some pdf files from their website.
When I use "Review - import PDF", it puts a diagonal line from the upper left corner to the lower right corner.
If I open the pdf file in Adobe Reader, it is not showing on that file. After I import it into a SoftPlan page, it shows up.
Can someone try to import the same pdf file and see if they get the same issue? I cannot figure out why the imported file adds this line to the pdf document.
The file can be found here http://www.huberwood...UCCO_AT_SOG.pdf
I also attached the individual file below and the test print that shows the diagonal lines on some of the imported PDF files.
Thank you!
#2 Yvon Gonthier
Posted 06 January 2015 - 12:21 PM
I got the same result but if I reprint the L-1 pdf you included with Primo Pdf then import that one with Review, the line doesn't appear.
#3 Thomas Davis
Thomas Davis
  • 309 posts
Posted 06 January 2015 - 05:50 PM
BINGO!
That did the trick!
Thanks, Yvon!
