As you can see on the attached screen shot that the interior window trim is attached to the inner 2x framed wall but the interior trim on the sliding door is attached to the block portion of the wall. How can I attach the doors interior trim to the 2xframed wall? I created a new wall using 8" block, 1" air space then, 2x4 insulated wall then drywall. So both walls are the same with the same settings. Help!
