faster symbol access
#1 Terry Babcock
Terry Babcock
  • 31 posts
  • LocationRochester Minnesota
Posted 02 January 2017 - 04:00 PM
has anyone set something up for quicker access to your "top ten" or however many you have symbols/openings/doors you use all the time rather than drill-down method.  I know I can keyboard shortcut to anything- leaving that as worst case back up plan for now.  I have a lot of keyboard shortcuts already.  I now have enough screen real estate now that I am envisioning either (1) symbols screen to stay open all the time to a custom folder with often used items (tried this as a child window, but it still closes all the time), or (2) a pallette "on screen" of common items copied forward to each job- seems clunky, how to handle visibility when in 3d...Probably overthinking this- the menus work fine, but I just dont like wasted/redundant steps. Ideas??
EDGE DESIGN GROUP
5234 80TH AVE SW
BYRON, MN 55920
terry@rochester-for-sale.com
"There is no reason anyone would want a computer in their home." Ken Olsen, founder of Digital Equipment Corporation, 1977
#2 Kevin Rabenaldt
Kevin Rabenaldt
  • 391 posts
  • LocationSan Antonio
Posted 02 January 2017 - 04:44 PM
I have thought of the same thing, some way to put the most used/common symbols in top of the order.  I am experimenting with creating a symbol group for each type of drawing (floor, foundation, elevations, electrical, cross sections, etc) with all the symbols i use on each of these drawings.  Then i place the group on the drawing off to one side, explode once, then use move/copy to place where I want them.  When done, just group delete the left overs.  I have not gotten finished quite yet.  I will see if it is a time saver.  I do place each symbol used in all four directions so I do not have to rotate when I move or copy them.  I did a shorten version of this for my site plans a long time ago and I know it speeds those drawing up, especially notes because I have them sized appropriately for the typical scale of a site plan.
#3 Steve and Carla Farnam
  • 680 posts
Posted 02 January 2017 - 06:09 PM
Under System Library you are able to sort the library placing the most often
used symbols at the top of the list.
#4 Philip Frank
  • 578 posts
Posted 03 January 2017 - 06:00 AM
As Steve and Carla said, resort the libraries. I have done this for nearly every symbol library as well as the openings and even the paint libraries. I have the 4" horiz paint listed 1st on my Siding folder since that is what I use 90% of the time. Big time saver and doesn't take much time to set up. Do yourself a favor and sort the libraries.
Posted 03 January 2017 - 07:45 AM
... I do place each symbol used in all four directions so I do not have to rotate when I move or copy them ...
Quicker than that ... if you put "DRAW SELECT" on a keyboard shortcut (mine's on "S"). Instead of using MOVE/COPY, use DRAW SELECT and draw at the right angle all the time. Much quicker especially if adding multiple items on multiple angles.
I use/create multiple symbols in the "Assembled Symbols" Library. All Bathroom items, Kitchen items, mechanical items etc. are together. That way just explode and draw select. Works well for me.
#6 Brian Berzinskis
Brian Berzinskis
  • 474 posts
  • LocationNew Jersey
Posted 08 January 2017 - 07:04 PM
I would wish to see either a "starring" type favorite system implemented or even when I select the Symbols, not having to click inside the Text Box for starting a keyboard based search. I will use the Seach tool often but it is annoying that I have to click in that little Text Box instead of the cursor automatically being there.
Posted 10 January 2017 - 12:47 PM
... but it is annoying that I have to click in that little Text Box instead of the cursor automatically being there.
What I find even more annoying is typing in a box to only find that it doesn't accept input unless you check the little box. If you are typing in a box, it should automatically check itself.
