timber truss
#1 Guest_chuck poore_*
Guest_chuck poore_*
Posted 22 February 2017 - 12:08 PM
I have a customer that wants to have the look of a timber truss at the entry of a covered porch. I have drawn more complicated trusses before , although it has been a while , using lines arcs and the solid polygon tool to make a 3-d symbol. This time I am having a problem when I click inside of the polygon all of the lines will not convert over ( some still show up as just lines) I am doing an 8/12 pitch so I copied a cross section to make sure I had the right pitch And started my symbol. Thought that had something to do with it, so I drew it all with lines adjusting everything to the correct pitch still have the same problem. My customers are tweeking the drawings and expect me to have a 3-d of this section of the house next week can anyone tell me what I am doing wrong? Chuck P  SOFTPLAN 2012 User since 1995 but I'm lost on this one. THANKS.
Posted 22 February 2017 - 12:49 PM
Typically, filleting all the corners should correct the problem with lines not converting to FORM SOLID POLYGON.
If that doesn't work, explode everything, and put it on a separate layer, and then draw 3d polygons over it, by snapping to the corners. If you have arcs, add a deflection to the polygon edge and then edit the radius to suit. (You can copy the radius by editing the line/arc below and copy and pasting the radius from the edited component).
For anyone unsure, if you create the truss on a separate drawing and edit the model to ONLY include that drawing, then exporting the symbol as a "3D" .DWG file is the easiest method of creating a working 3D symbol.
#3 Guest_Chuck P._*
Guest_Chuck P._*
Posted 22 February 2017 - 04:17 PM
Hey Keith man you have saved my life I didn't do it with the fillet tool the last time I remember I just zoomed in real tight and tried to make sure all edges were closed . The fillet  worked like a charm,  I am at a lost to the rest of you guys I am a builder first and a designer second my drawing time is on rainy days and of the evening, so every little thing I can talk to some of you guys really helps . Thanks again for your help have a good one catch you next time. Chuck P.
  • admin likes this
