Box Bay Window
#1 Ron Sirolli
Ron Sirolli
  • 304 posts
Posted 22 February 2017 - 05:11 PM
i am trying to figure out howto do a twin box bay window can i get some idea
thanks Ron
#2 Terry Babcock
Terry Babcock
  • 31 posts
  • LocationRochester Minnesota
Posted 23 February 2017 - 05:38 PM
Are you thinking something simple like this...or more complex?
EDGE DESIGN GROUP
5234 80TH AVE SW
BYRON, MN 55920
terry@rochester-for-sale.com
"There is no reason anyone would want a computer in their home." Ken Olsen, founder of Digital Equipment Corporation, 1977
Posted 23 February 2017 - 07:35 PM
I think that Ron means an actual boxed bay with windows on the side. I can make a 90 degree bay without a problem, but I can't find any way to make the front window two sections. So it's probably the same issue Ron is having. If anyone can fix it, I too would be interested in the solution.
You can cheat and add a single vertical grille bar to a plain window, but that won't work if the window itself has to have grilles
#4 D M
D M
  • 402 posts
  • Location..
Posted 25 February 2017 - 03:34 PM
If this is what you had in mind, ..
For this I created a thin exterior wall with siding, .. 2” stud depth, .. just to keep the window jamb thin
The Main Exterior wall has a blank arch, sized and positioned (v and h) as I needed
Casement windows inserted into my thin exterior walls (the box bay projection) and sized to suit.
Cube solid placed below projection and positioned to suit
I tested various exterior and interior trims on the units until I got want I wanted, ..
  • John Jones likes this
#5 Ron Sirolli
Ron Sirolli
  • 304 posts
Posted 26 February 2017 - 09:57 AM
THIS IS GOOD BUT I DONT WANT SIDE WINDOWS I TRY THAT WITH A BOW AND CHANGE IT TO A 90 % BUT HOW DO YOU GET RID OF THE SIDE ONES
I TALK TO RANDY AND WE TALK ABOUT BUILDING WALLS BUT I WOULD JUST LIKE A BOX THAT ANDERSEN HAS THEM PROJECTION IS 22" 90-C25-15
I WOULD HAVE TO CHECK IF THAT MEET EGRESS FOR BEDROOMS
#6 randolph cohn
Posted 09 March 2018 - 10:41 AM
how about creating a box window out of walls, openings and roof
and than making that into a 3d symbol ?
