Electrical Take-off
#1 D M
D M
  • 402 posts
  • Location..
Posted 13 March 2015 - 08:53 AM
Is Softlist capable of listing Electrical Rough-in components?
Quantity of Boxes, Switches (1 way, 3 way), Receptacles, Wire, etc ..
Any advice much appreciated.
Thanks, ..
Doug
  • 5,301 posts
Posted 13 March 2015 - 08:56 AM
Softlist is able to list every item you put on the drawing. So electrical receptacle symbols etc. will list as such. Depending on how your Softlist is set up
#3 D M
D M
  • 402 posts
  • Location..
Posted 13 March 2015 - 09:11 AM
Thanks, ..
I've just done a small floor plan, added some plugs, lights and switches, .. created 'Material List', .. with nothing electrical showing in the list.
I'm assuming then, that the default settings for Softlist do not include the Electrical?
The Index in the Softlist Manual does not direct me to anything helpful, .. .
Is there a simple solution (hopefully) where I can 'click' a setting or two to get what I want?
Doug
  • 5,301 posts
Posted 13 March 2015 - 10:23 AM
I just ran a quick "Standard detailed" takeoff, and everything shows up under "Finish Electrical". I assume you'll have to create your own formula's for wiring, since that's not drawn.
#5 Rod Leger
Rod Leger
  • 31 posts
Posted 19 March 2015 - 04:39 AM
Doug,
Some electrical symbols do not report if you change  calculated to description.
6" cans are one of them.
Go to Softlist > Symbol Libraries > Electrical > Ceiling Lights
at the far right you will see Description Column
There are 2 choices.  Calculated and Description
Change to description and name it say 6" recessed can.
It does not show in the report
If you leave the calculated box check it reports.
I am compiling a list to send to Tech Support
Some of the Electrical symbols are not the only ones (symbols) that do not report.
A work around is to define the symbol in the Material Definitions
Make sure you sync the sequence number to the report you use
Rod
Softplan 12 - 2012
Softlist
Review
Windows 7 Ultimate
I7 2600K
16GB Ram
2- 23" monitors
