Good Morning,
Has anyone found a way to show rope lighting on a rendering? I need to show the actual strings of lights, not hide the source behind a crown, for an exterior restaurant/bar area.
Thanks for any tips or suggestions..
Dave
Posted 14 March 2017 - 12:57 PM
That seems to be where I am having an issue. First try I did not do that. After seeing your post I have tried several times to recreate the symbol. If I use the symbol wizard in plan mode, the lighting does not come into the block. if I use the wizard in 3D mode (where I can see my light sources), I do not get my rope lighting shape into the symbol.
Thanks for your help, and sorry I am not very experienced with block creation...
Dave
Posted 14 March 2017 - 01:20 PM
If it's just a polygon shape with atmospheric lights, you don't need to go thru the wizard. Draw your polygon shape in a room in your plan or somewhere you can see the light reflections. Switch to 3D mode to see if the lighting effect is good. If not, edit the atmospheric light sources as needed (you will probably need multiple atmospheric lights as shown in item #2 above). Once you are satisfied with the light effect, in plan mode select System Options>System Lbrary, select the electrical library you want to put it in, click One Step and draw a box around (leaving plenty of room around the symbol). Your electrical symbol should now be good to be used. Make sure if light effect doesn't show that the light is on (edit symbol, Lights tab and box On checked.
If it doesn't work, try to zip the symbol so you can insert it in a post so we can have access to verify (click More Reply Options when enrering your post to allow you to insert an attachment).
Posted 15 March 2017 - 08:55 AM
I'm not sure that the type of lighting you're using is the best for this case. Try using the Atmospheric Lights instead of the Direct Lights and position them directly on the 3D polygon. After, and only after putting the atmospheric lights over the 3D polygon can you create your electrical symbol. Crucial point; it must be in your electrical library, preferably lights.
Hint; I've created in the past electrical symbols for under cabinets lights and they work when stored under lights but I've had ceiling lights that worked only when created and saved under ceiling lights (didn't work when saved only in lights). Might just be a setting.
Posted 15 March 2017 - 09:49 AM
ok... I'm getting closer. I was putting all my custom symbols in one library. Creating the block and putting it under lights brings the lighting along with the line work. I can place the symbol in plan, and see the light icons in 3d mode. It does not display in my model. I think I have all mode visibilities that it could be turned on. I can't edit the offset so maybe it is below the grade? I also can't rotate the item in 3D so it is hanging down. I did not get to set the 3D orientations when I created the block.
Thanks for your assistance and patience!
Dave
Posted 15 March 2017 - 10:47 AM
In 3D, verify under Material tab at top that for the solid that you used that the Display box is checked.
Your electrical symbol should be set to reference the floor or ceiling if you prefer depending on your needs. You can set right away a standard offset if a most common offset exist for you. When you put the symbol on a plan, you can uncheck the Cleanup box in the common tab if you want to adjsut your offset.
You can't rotate a symbol along the vertical axis. Since your rope symbol is just a polygon which doesn't really have a up or down, you can set the atmospheric light to "Both". If you need to pont in iether direction, select Up or Down as required or you may have to create a symbol with up and one with down if that's what you need.
Posted 15 March 2017 - 12:00 PM
The good news is the symbol displays and the lights work when I place it in a fresh project. I still can't get it to render in my model, but softplan electric items show
The attached jpeg shows what I am trying to do, but I just placed light above the tables, so what is shown is not lit from the white curves.
The light will be hanging between the beams over the patio, and it will be hanging loose so it will curve down. Can I change the block to 3D so I can orient it correctly? See attached screen shot fro how the block displays in plan.
Dave
Posted 15 March 2017 - 12:47 PM
To rotate the symbol, you need to put it in a drawing that it's the only thing showing up. Generate the 3D. You'll have to play around a bit to find the 3D symbol. While in 3D, do File>Export>Dwg. This will create a new 3D symbol. Create a new 2D electrical symbol and link the new 3D symbol to it.
Maybe someone has a better explanation or way.
Posted 15 March 2017 - 01:48 PM
Last question, Yvon, then I'm going to give up! I like the idea of a beam. It works great for my curve, but when I make the block the beam is not recognized as a shape, so just the lighting elements go into the block. As you can see, the beam displays as dashed lines. Any final suggestions?
Thank you again, very much!
Dave
Posted 15 March 2017 - 02:40 PM
Ok. I think that you have to start with a blank plan to create the symbol in 2 steps;
Hope I didn't miss any steps, have to leave for a meeting.
