This roof is not being my friend today. I am attaching a couple screen shots of the problem area. I cannot seem to come up with a way to make the "circled section" over the garage extend to the main roof correctly. Any ideas?
Roof Question
Started by
Miles Millspaugh
, Mar 18 2017 07:20 AM
Posted 18 March 2017 - 07:32 AM
I would use 2 separate roofs.
One over the garage with hips left and right and gables on front and rear.
The second one will connect the garage roof to the main roof.
On the rear (garage side) it will be intersect and select "vertical".
The front of this second roof will intersect the main roof.
Left and right will be hipped.
This will cause some unwanted lines where the two roofs meet (that you now see as a solid roof plane).
Easy enough to clean up later.
Posted 18 March 2017 - 07:43 AM
