Rendering finishing touches
backgrounds city scape
14 replies to this topic
#1 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 20 March 2017 - 03:01 PM
Good Afternoon,
I have been working on this building for a while, and thanks to all of your assistance it is pretty close to finished.
Is there some way to make this look like part of a street scape without creating a series of buildings?
If not, can I cut down on all the extra grass and sky?
Thank you, again,
Dave
#2 Martin Livingston
  • 693 posts
Posted 20 March 2017 - 03:17 PM
If you have Photoshop you should be able to drop it into a suitable image. The other option is to find an image you can save as a Softplan background. then you need to play around with the camera location and field of view settings to achieve the illusion that you are looking for. You will have to turn off the horizon and create a site plan first.
You can probably find what you are looking for on Google Maps. Here is a sample of a commercial lot near my office from Google Maps. I dropped in a Softplan model. Its a rough, 10 minute job but you get the idea
  • Keith Almond likes this
Posted 20 March 2017 - 05:57 PM
Nicely done Martin. Pretty Impressive for a 10 minute job.
#4 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 21 March 2017 - 08:55 AM
Thanks, Martin.  Here is how it came out...
  • Martin Livingston, Keith Almond, Steve and Carla Farnam and 1 other like this
#5 Yvon Gonthier
Posted 21 March 2017 - 09:06 AM
Very nice. Sure blended in good.
#6 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 21 March 2017 - 01:14 PM
Thanks Yvon.
One last question. What is the best way to show a client alternate finishes?  He would like to see it with white brick and some other variations.  Right now I am creating alternate projects.  I don't think I can save different surfaces as building options.  Any recommendations?
Dave
#7 Yvon Gonthier
Posted 21 March 2017 - 01:46 PM
While in 3D, edit the 3D to have your 1rst finishes options. Then, still in 3D, select File>Material File>Save and give it a name. Change your finishes to create option 2 and go thru the same process to save under another name. After that, to go from one option to the other, just do File>Material File>Load and select the option.
Look at the same principle to save Views.
In the 3D go to:
FILE > MATERIAL FILE > SAVE and then edit your finishes as necessary then RESAVE the render options with a new name, as many times as you want. You can then reload the saved options any time you want to regenerate the project.
#9 Yvon Gonthier
Posted 21 March 2017 - 02:57 PM
Quicker way to switch from one material file to another is by clicking on the tab of the bar identified as "Material File: Project". The name of the material file that you choose will appear in that area also.
#10 Martin Livingston
  • 693 posts
Posted 21 March 2017 - 03:47 PM
That's an awesome result Dave!
#11 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 22 March 2017 - 06:42 AM
Thanks, Martin.  Google street as you suggested!  Thank you all for your help.
Dave
#12 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 23 March 2017 - 01:26 PM
it seem like neither the material file save or the view file save keeps the background image and horizon settings.  do I need to recreate those each time?  My street view background only works from this camera angle...
Dave
#13 Keith Almond
Posted 23 March 2017 - 01:37 PM
... do I need to recreate those each time?
Not sure what you mean by each time. Unless you change the materials or render options (or rotate the view file), the view file should stay the same.
One tip though. Once you save the view file, EXIT the 3D, and open a new 3D to rotate. The view file is movable the same as any other 3D file, so if you rotate the view whilst in a specific view file it will stay rotated unless you reload it ... and it's easy to re-save it in a new location.
#14 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 24 March 2017 - 08:11 AM
I created the rendering and placed it on the street view, and it looks great, so I save it as an image.  I also want to present some other angles of the building to the client, so I change the background picture and rotate to the new view, and save an image file.  Repeat as needed.  Now I make a few small tweaks to the landscaping.  What should I have done to save the first view/background/angle/camera position so I do not need to readjust and align everything again?  I hope that makes sense...
Dave
#15 Keith Almond
Posted 24 March 2017 - 10:21 AM
You should be saving a VIEW file, not an image file. This will always return to the saved view. It doesn't save the background, as far as I can tell, it's just the camera location.
However as I said above, once you save the view file DON'T rotate that view EVER, unless you make sure you don't save it.
Also tagged with one or more of these keywords: backgrounds, city scape
