Box Bay
Bay
#1 Wesley Penner
Wesley Penner
  • 59 posts
Posted 15 April 2017 - 05:48 AM
How do you approach drawing  a box bay like this in SP. I suppose one would use walls and floor and offsets? It seems you would need walls for the roof to reference to something. But how does one run the wall through under the bay and have it cover the main floor?
#2 Sam Morgan
  • 851 posts
Posted 15 April 2017 - 05:55 AM
I use a square arch...height the size of your walls and then offset up
#3 D M
D M
  • 402 posts
  • Location..
Posted 17 April 2017 - 07:25 AM
Look at these posts, ..
http://softplan.com/...-boxed-windows/
http://softplan.com/...box-bay-window/
#4 Tim Stockton
Tim Stockton
  • 313 posts
  • LocationWichita, KS
Posted 17 April 2017 - 03:33 PM
If you don't want the dashed lines from the square arch that Sam mentioned, you can always use a blank arch.  The other option would be to use individual walls.
#5 Wesley Penner
Wesley Penner
  • 59 posts
Posted 19 April 2017 - 04:55 AM
Thanks for your help and the links to those posts. I tried searching "box bay" but the forum doesn't allow you to search on only three letter words. I have always found the search on this forum quite a hindrance to actually finding things. I actually have better luck going to Google to search this forum. Thanks again.
