Extend roof ridge ONLY
roof ridge
#1 Dave Pazyniak
Dave Pazyniak
  • 340 posts
Posted 18 April 2017 - 05:53 AM
Good Morning,
I need to extend the ridgeline on the rear of the house to reach the main two story roof (see attached), but I do NOT want to extend the overhangs any farther past the second story rear wall of the home.  Is this possible?
Dave
  • 3,925 posts
Posted 18 April 2017 - 06:12 AM
Yes, you have to trace that particular wall edge with 4 edges.
Like this ...
You can't have a gable and an intersect on a single edge, so you need more edges. You nay also fall into the problem that Softplan doesn't like referencing two edges to the same wall, so you may have to break the wall into two parts too.
#3 Dave Pazyniak
Dave Pazyniak
  • 340 posts
Posted 18 April 2017 - 06:41 AM
Perfect.  Thank you.
#4 randolph cohn
Posted 18 April 2017 - 09:33 AM
try "ADD" roof
#5 Sam Morgan
  • 464 posts
Posted 18 April 2017 - 10:10 AM
I usually just "extend" that roof till the ridge intersects and then "draw hole" to get rid of the unwanted down at the eave.
#6 Steve and Carla Farnam
  • 357 posts
Posted 18 April 2017 - 10:32 AM
We use Sams method. Create intersecting roof with vertical plane, extend past ridge connecting point and then back to
dotted line showing valley intersections. Cut hole to eliminate extra roof and uncheck soffit and fascia boxes.
#7 randolph cohn
Posted 18 April 2017 - 01:32 PM
showing extended ridge into sloped roof
used only ADD ROOF.
also playing with rotate texture of the siding and
it got carried away.  do we have a command called
ROTATE top of gable wall ?
the ADDed roof took 4 seconds or less.
left click to enlarge
Also tagged with one or more of these keywords: roof, ridge
