Add exterior trim button not working
9 replies to this topic
#1 Dave Pazyniak
Dave Pazyniak
  • 402 posts
Posted 26 April 2017 - 11:27 AM
Good Afternoon,
working on a 2016 drawing in 2018, with an elevation that was saved to a softplan file.  I edit a window, then click on add exterior trim and nothing happens.  Add a shutter right above it works fine.  Tried several projects with the same result.  process works fine in 2016 following the same steps, it adds a trim board over the window, that can then be edited.
Does this work for anyone?
Dave.
Posted 26 April 2017 - 11:32 AM
You'll probably find the trim is there ... try and edit it ... I think that it is REALLY thin though. Try and edit it and change the width.
#3 Paul LeBeau
Paul LeBeau
  • 7 posts
Posted 26 April 2017 - 11:55 AM
I am having the same problem.
Posted 26 April 2017 - 12:31 PM
Again ... right click - EXTERIOR TRIM > EDIT and change the thickness from 0.000" to something a little more substantial ...
Although why the default to no thickness, I'm not sure.
Attached File  2017.04.26_14h28m50s_003.png   34.37KB   0 downloads
#5 randolph cohn
Posted 26 April 2017 - 01:13 PM
try > system options > drawing defaults > material dimensions > openings trim options
Posted 26 April 2017 - 01:27 PM
I don't believe that the dimensions themselves are selectable, just the trim, which defaults to 0.000" on elevation openings no matter what is selected.
#7 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 26 April 2017 - 03:19 PM
Trim is adding with 0.000" size. Reported on CO-47169. Should be fixed in next patch.
#8 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 27 April 2017 - 12:33 PM
Please try it now. Should be fixed in the 2018.3.1 patch.
#9 Keith Almond
Posted 27 April 2017 - 01:36 PM
Yes, it appears to be working correctly now.
#10 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 28 April 2017 - 10:50 AM
Thanks Keith.
