THIS MAY SOUND STUPED BUT I CAN NOT FIND THE FLOOR JOIST LINES FOR THE SIZE AND DIRECTION
IN 16 THERE WHERE THERE ARE THEY STILL THERE ARE DID THEY RELOCATE THEM.
SO I AM NOT SURE WHERE THEY ARE NOW.
THANKS RON
Posted 30 April 2017 - 09:57 AM
Ron, I think you may be referring to the note used to describe your joist layout? If so, type your note, say, "16" I-Joist 19.2" o.c.", then under the properties for the note check the box for underline and they chose you underline type, usually the last one the funny half arrow on each end.
Posted 30 April 2017 - 10:38 AM
Posted 30 April 2017 - 10:55 AM
Then you have to separate your note lines. Create the overall look you want with your note layout assuming you have multiple lines. They explode your note, edit the last line and use the appropriate underline you want. If you want, create all your joist layout notes that you use offen and then make a symbol out of each one. You can also explode the symbol once created and edit to what you need if not your common joist layouts.
Posted 30 April 2017 - 11:00 AM
Posted 09 May 2017 - 07:09 PM
I'd love to be able to make that line ONLY under the last line of a multi-columns note. I never use it because all my joist notes are multiple lines and it looks ridiculous under every line
I agree. I will only sometimes use it mainly on my as built drawings when all I label is "2x8 @ 16 OC" and then use the joist sets on my proposed framing.
