This is my first post. Looking for a way to add arch trim above windows. I have added two pictures. With wood trim and brick.
Arched Window Trim
#1
Posted 22 March 2015 - 06:25 PM
Martin Wrobel
Superior Home Design
Michigan
Softplan 2024
Posted 22 March 2015 - 07:06 PM
Martin Wrobel
Michigan
Softplan 2024
Posted 23 March 2015 - 11:59 AM
one easy way is to use
a windows (flat top)
and an arch opening (pick the style of top arc / camber, round, etc
with trim at the top of it of the arch) TIP: play with it.
NOTE: put a SOLID / plane to fill in the cut wall that the
curved arch makes above the flat top of the window.
than COPY SURFACE of the siding, stucco, etc and
PASTE Surface on the plane.
note: shutters from the window or the arch
v10 to future 2016+
#5
Posted 24 March 2015 - 10:32 PM
Softplan has a pediment button on opening/exterior trim...that would be a great place to incorporate some sort of arched trim as shown in Randys post above. I've been using Randy's method for years, the only flaw is its treated like a window so you'll see this on the inside of the house also.
#6
Posted 26 March 2015 - 06:34 PM
Martin Wrobel
Michigan
Softplan 2024
#8
Posted 27 March 2015 - 06:36 AM
