Activated my second key and keep it at the office I work in. Put several drawings in the cloud. At home nothings showing up at start up on the cloud column ? obviuosly I'm not doing something right..Seems like they should be there.
The Cloud
Posted 23 May 2017 - 10:09 AM
Are you sure that you had them save to the cloud? I ask because I thought that as I saved them up they would go but I did not have "Save to Cloud" clicked. Also when you are at office or wherever and save them they should change and show a green dot or share symbol. If there is nothing there or it is not green it did not save.
Posted 23 May 2017 - 10:14 AM
They won't show up. The list that shows up on startup, is generated by the key. As far as I'm aware, for the list to show, you have to use the same key.
Posted 23 May 2017 - 10:28 AM
That is correct Keith. Sorry Daniel. I did not read it all correctly. If you are using separate keys you need to share the project with the other key.
