modify
7 replies to this topic
#1 BRUCE PAGE
BRUCE PAGE
  • 27 posts
  • LocationEAU CLAIRE, WIS.
Posted 24 May 2017 - 12:41 PM
There is a modify icon by the move command. I cannot figure out what it does. I tried help.
Posted 24 May 2017 - 12:46 PM
It's seems to be sometimes adjust, sometimes rotate and sometimes move depending on what/how objects are selected. For instance it will adjust the size of or rotate a post, but move dimension text - not the dimension.
It doesn't seem to be very controllable, and until I learn more, am going to have to be very careful with it.
#3 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 24 May 2017 - 02:59 PM
In short,  the Modify command is a single action that allows you to Move, Adjust, or Rotate items depending on the placement of the cursor. When modifying objects such as interior details, it might be advantageous and timesaving to use the single Modify command rather than switching between the three separate commands
Search 'Using the Modify Command' under Help for the full list of functions that the Modify command can accomplish.
#4 BRUCE PAGE
BRUCE PAGE
  • 27 posts
Posted 24 May 2017 - 05:01 PM
It works great. Thanks.
Posted 25 May 2017 - 06:40 AM
I don't know why, but I don't get ANY visual prompts to indicate what will happen when using the modify command. No move/adjust/rotate indicators at all EVER no matter what I do. Is there something that I need to turn on?
#6 Jim Johnson
Jim Johnson
  • 289 posts
Posted 25 May 2017 - 07:17 AM
Cursor Options>Display Snap Points
Posted 25 May 2017 - 07:28 AM
Already turned on ... Still no indication of what MODIFY is going to do!
Attached File  2017.05.25_09h27m46s_001.png   20.67KB   0 downloads
The HELP menu item implies that HOVERING the cursor over an item will trigger the MOVE, ADJUST & ROTATE indicators ... is that the case? If so, then it plain doesn't work for me. Is anyone else seeing this behaviour.
#8 Daniel Zanoli
Daniel Zanoli
  • 228 posts
  • LocationNorthern Michigan
Posted 25 May 2017 - 08:02 AM
I gave up on that one a while ago. I think my arthritis and carpal tunnel, and caffeene shakes wont let me use it,
