Knee wals as Railings on a stairway
stair railing
#1 Michael Trostrud
Michael Trostrud
  • 28 posts
  • LocationCarlsbad, CA
Posted 06 June 2017 - 02:40 PM
Hello all,
Looking to create a stair railing that is a knee wall instead of posts and spindles.
Anyone?
#2 Yvon Gonthier
Posted 06 June 2017 - 03:05 PM
Two options I can see.
1- If it's a wall starting from the floor and extending as a knee wall (railing height), draw wall sections as needed and select "Rake Top" when you edit the wall. You will need to do calculations for your various heights.
2- If the bottom of the knee wall follows the slope of the stairs, you could draw a railing with a square handrail. Turn off posts, toe rail and spindles and set the depth of your handrail to the same as the Handrail Height.
  • Michael Trostrud likes this
#3 Michael Trostrud
Michael Trostrud
  • 28 posts
Posted 06 June 2017 - 03:19 PM
Thank you kindly sir!
#4 Michael Trostrud
Michael Trostrud
  • 28 posts
Posted 16 June 2017 - 09:20 AM
Hello, I was able to utilize rake bottom and rake top to achieve the desired results. This way I get a semi-accurate material list as well as the desired effect.
Question: It would be nice to add at top cap to this. perhaps that's where a railing with no posts and no spindles and no toe rail would come in handy?
Posted 16 June 2017 - 09:32 AM
Use a custom wall definition that has a oak (or similar) cap defined specifically in the wall.
#6 Yvon Gonthier
Posted 16 June 2017 - 10:14 AM
As mentionned by Keith
