Window Trim Size
#1 Brian Berzinskis
Brian Berzinskis
  • 470 posts
  • LocationNew Jersey
Posted 12 July 2017 - 07:57 AM
I have changed my window trim to custom profiles when adding Exterior Trim to an Elevation Opening.
The only problem is that even though my side casing profile is 4 inches in width, it seems to always default to the 3.5 inch width which was the width of the default casing not my new custom profile. Is there somewhere in the settings to change this because I could not seem to find it and I can change it in the Edit menu of the trim every time but would prefer it to be the default?
Posted 12 July 2017 - 08:39 AM
It should be set up in MATERIAL DIMENSIONS > OPENING TRIM OPTIONS > EXTERIOR TRIM PROFILES
#3 Tom Rogers
Posted 12 July 2017 - 09:54 PM
Just a thought as I have noticed this in other items, are you doing it in the System menu, project menu or drawing menu?  I would guess you are doing it on the drawing and each window but perhaps adjusting the trim in project and then updating drawing to project settings would work.  Not in front of Softplan to verify but just a thought
#4 Brian Berzinskis
Brian Berzinskis
  • 470 posts
Posted 24 July 2017 - 06:07 PM
When I go into that dialog under System Options, Exterior Trim Profiles allow me to select profiles but not change the width of the the Side Trim even though my profile is 4 inches the window trim seems to come in at 3.5 inches whenever I add it.
