I need the carpet texture in this photo. Appreciate your feedback.
Carpet Texture
Posted 16 July 2017 - 03:49 PM
Do you have a manufacturer's name and SKU number? They may have a decent image on line that you could turn into a texture.
Posted 16 July 2017 - 04:51 PM
do you mean you want a carpet that looks like the pavers under the furniture
(the pavers look like granite or marble > check those folders in softplan interiors)
or
do you mean the floor material that's OFF to the left in the image ?
or are the pavers under the furniture really carpet squares ?
in softplans INTERIOR textures / PAVESTONE / marble / granite ??????
or
try other tiles in the different texture folders.
click on LIST at the lower right to get NAME to show.
i tried one that's by no means exact but sort of the same pattern but not.
find > "floor tile little squares"
for it to just cover a portion of the floor, use a SOLID polygon.
give it a HEIGHT of 1" and make sure it's top is just a hair
higher than the floor it sits on. (it will looks like it's recessed into the main floor
do a SURFACE EDIT:
edit the size (check maintain aspect ratio)
learn how everything works if you haven't already done
any of that fun stuff.
go into OPTIONS / MODE OPTIONS
and check "enable relief depth" (this will give it a rougher finish
to look more like carpet) btw, i don't see why you mention
this tile looks like carpet
when you doing the surface edit, play with
the numbers > higher the number the ROUGHER
the texture gets.
i know i didn't answer your question very well
and i didn't check out all the available carpet
or tile textures that we're given with softplan.
you might want to find out who makes that tile/carpet
and call the company and have them send you
a matching texture or maybe the whole line.
if you need any help, feel free to email me at:
rpcdesign@aol.com
put "softplan rendering help" in the subject line
have you "contact info" in the email.
NOTE: you can send your SPF drawings and your APP file
and a saved material file if you wish.
v10 to future 2016+
