walls
walls selection
#1 Troy Lachcik
Troy Lachcik
  • 71 posts
Posted 01 August 2017 - 11:04 AM
Has anyone noticed that when you try to add a reference point to an exterior wall that it wants to put the point on the material and not the bearing?  It also happens when drawing a line or box.  Is there a setting that I am missing?
Posted 01 August 2017 - 01:25 PM
As far as i remember, it's always been that way. There's no setting, but once placed, the point can easily be moved to where you want it
Personally I think it should snap to the same point on the wall that's defined as the TRACE WALL POSITION in the wall definition.
#3 Troy Lachcik
Troy Lachcik
  • 71 posts
Posted 01 August 2017 - 01:33 PM
On 2016 the outside material was never able to snap when the material was turned off in the wall definitions. This is a new thing in 2018.
Posted 01 August 2017 - 03:53 PM
Cant comment ... I've never turned exterior material off!
