Help with Lining up Board & Batten
14 replies to this topic
#1 Marcie Franklund
Marcie Franklund
  • 24 posts
Posted 10 August 2017 - 08:14 AM
Hi, I am trying to place board & batten in the gable peak and part of the wall below it but I'm stumped on how to get the lines of the board & batten to line up.
I tried editing the top of the wall to "Rake Top" & "Fit to Roof" which worked for the B&B but it also pulled the stone with it.
I'm pretty new to renderings so any help would be much appreciated!
Marcie
Attached File  b&b issue.jpg   76.21KB   4 downloads
Posted 10 August 2017 - 08:26 AM
There's no way to actually line up separate textures (that's the subject of an entirely different grumble), as they all have a start location that they generate from.
You have to make them a single texture with (as you tried) "FIT TO ROOF". If it also pulled the stone with it, then you will have to go into the wall definition itself and check FIXED on the stonework.
This may create other issues if you have a moved transition in the stonework, but we can cover that later if it occurs.
#3 Marcie Franklund
Marcie Franklund
  • 24 posts
Posted 10 August 2017 - 08:37 AM
Thank you! Checking the box "fixed" worked perfectly!
#4 Mike Downing
Mike Downing
  • 82 posts
  • LocationPortola, Ca
Posted 10 August 2017 - 12:43 PM
Plus one on that "Grumble" Keith
  • Morgan Painter likes this
Mike Downing
#5 Allen McDonnell
  • 955 posts
  • LocationIllinois
Posted 10 August 2017 - 01:06 PM
Agree....add another grumble.
Posted 03 January 2018 - 02:29 PM
Dear Softplan,
Are there any plans to fix this issue. two storey units in board and batten really look stupid since we can't realign surface textures the way we could with offsetting paint lines.
Attached File  2018.01.03_15h13m18s_002.png   381.85KB   2 downloads
PLEASE!
#7 Mark Petri
  • 1,510 posts
Posted 03 January 2018 - 04:01 PM
Agreed. It is a very horrible look when presenting drawings to clients.
#8 Harald Schwegel
Harald Schwegel
  • 74 posts
Posted 03 January 2018 - 04:05 PM
The misaligned textures in 3D are a known issue. .CO-47414
#9 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 04 January 2018 - 05:37 AM
HOW ABOUT IF YOU FIT TO ROOF ON THE BOTTON DO NOT LET THE ROOF DO THE GABLE END
#10 Keith Almond
Posted 04 January 2018 - 07:51 AM
HOW ABOUT IF YOU FIT TO ROOF ON THE BOTTOM DO NOT LET THE ROOF DO THE GABLE END
That only works on a single storey structure. Trying to do it on a two storey causes more problems than it solves.
#11 Ron Sirolli
Ron Sirolli
  • 262 posts
Posted 05 January 2018 - 05:24 AM
doing it for elevation view work or change the hight of the wall I have done that but just for a 3 d view
#12 Sam Allen
Sam Allen
  • 133 posts
  • LocationSan Antonio, Texas
Posted 05 January 2018 - 08:41 PM
To get the proper look on a two story...I draw a second drawing (just for the 3D) where the first floor walls go all the way thru the second floor and erase the second floor walls as needed. It's just an exterior shell to get the 3d to look correct.  It works but it sucks......real time waster.....
#13 Grant Myers
Grant Myers
  • 26 posts
  • LocationWashington State
Posted 13 February 2018 - 05:06 PM
Good to see this brought up, its something that has bothered me since I started using Softplan.
Hope this gets fixed.
#14 Daniel Zanoli
Daniel Zanoli
  • 228 posts
  • LocationNorthern Michigan
Posted 13 February 2018 - 06:27 PM
Like you Ron I've drawn those walls at 17 ft. and put both story windows in it just to get a good 3D render.  Made a whole different drawing for the model and one for the drawing itself. If you could just offset the texture side to side..
#15 Keith Almond
Posted 13 February 2018 - 07:17 PM
... If you could just offset the texture side to side..
Or even up and down ... The ideal would be to be able to specify the ORIGIN point, or alternately ONLY have a single ORIGIN point for all textures in the model as 0,0,0 ... since the textures are seamless with a single origin, the should ALWAYS line up consistently.
