CAN SOME ONE GIVE ME A IDEA ON WHEN YOU DESIGN A KITCHEN WHAT IS THE BEST WAY
TO FIGURE OUT OPENING BECAUSE I NEED THE TRIM OUT TO OUT SIZE SO I CAN DESIGN
HOW TO SET THE CABINETS SOUNDS STUPED BUT THAT IS THE WAY.
THANKS FOR ANY HELP
RON
Posted 16 August 2017 - 03:13 PM
If you show your trim you can see dashed red lines on your plans (if you have show non-printable items showing) you can see where the trim is. Then next big thing is actually having the trim be properly sized to represent what will actually be done in real life. Being SP places trim at the outside corner of the jamb (not realistic in real life) you will have to compensate for the offset being different. Also, you may have to customize between window and door openings being jambs are not all alike.
