I've searched for an answer to this problem, but haven't found anything.
I've just recently started using v.2014 again after a couple years hiatus. Since I last used SoftPlan, my computer has been upgraded to Windows 10 Home 64-bit from Windows 7. The system is an Intel Core I7-4790k at 4.0Ghz with 16Gb of ram. The problem is whenever SoftPlan is active, the Windows Asterisk sound chimes continuously about every 10 seconds or so. From what I can gather, the Asterisk sound triggers whenever a popup window notification occurs, although none does. I have been able to work by disabling the specific sound in Windows and haven't noticed any other adverse effects. Does anyone know what may be causing this?
Thanks, Roger Johanson
