Plan set drawing scale
#1 Paul James
Paul James
  • 251 posts
Posted 17 August 2017 - 07:18 PM
Is there a way to preset what scale drawings load into a plan set at when dragging?
The majority of the time I use 1/4"/1'. If I drag a drawing onto the page I'd like it to come in at that scale- if it doesn't fit I would most likely use another sheet not downsize the drawing- talking mainly about floor plans.
It doesn't really make sense to me to have a drawing load at 0.0852"/ 1' just because I happened to drag into an odd spot on the sheet.
#2 Steve Haarmann
Steve Haarmann
  • 645 posts
Posted 18 August 2017 - 08:26 AM
I agree with this completely.
I primarily use 1/8" scale and woiuld like it to always use this scale uinless I decide to change it.
The alternative would be to select a standard scale that will fit.
It is embarrassing to publish a plan set after dragging a drawing onto the sheet that LOOKS close to scale but then you look at the title and it is really 1' - .1126"
This has been suggested to tech support and I hope we see it in a patch or at least in the next release.
Posted 18 August 2017 - 08:38 AM
Agreed, I'd like to ALWAYS pull in my drawings at 1/4" scale whether they fit or not, and then use MY judgment how to adjust from there.
But to answer your question, I don't believe there is a way to lock the scale at the moment.
