Custom 3D Objects
8 replies to this topic
#1 Dion Mulrooney
Dion Mulrooney
  • 28 posts
Posted 07 September 2017 - 09:54 AM
Is there anyway to create 3D objects yourself? other than using lines to make isometric drawings? Like a custom wine rack for example, with curves and lots of detail.
Brittany Kelly
(Dions the owner  :) )
Mulrooney's Construction Limited
#2 Yvon Gonthier
Posted 07 September 2017 - 10:37 AM
You can create from solid, combine with existing symbols, create with SketchUp or download symbol from 3D Warehouse or other sites (they can de dowloaded and modified in SketchUp).
#3 Martin Livingston
  • 691 posts
Posted 07 September 2017 - 12:13 PM
You can use AutoCAD  or Sketchup and use the resulting DWG or SKP files in the Softplan symbol set up. You can also build most this using Softplan solids to make 3D objects.
Here is a 3D peg wine rack I made in Autocad
  • Yvon Gonthier likes this
  • 5,092 posts
Posted 07 September 2017 - 12:19 PM
Can you post an example of what you want to see.
You can EXTRUDE any shape into a 3D solid within Softplan, by drawing shapes and using BLOCK FORM POLYGONS and FORM SOLID POLYGON.
#5 Dion Mulrooney
Dion Mulrooney
  • 28 posts
Posted 12 September 2017 - 04:48 AM
This is what Id like to create in 3D.
Fairly new to softplan, and would like to experiment a bit.
Brittany Kelly
#6 Guest_darin.swanson_*
Posted 05 October 2017 - 01:56 PM
How can you move the polygons? Like... they are laying flat, how can I stand them up on end or side etc..?
  • 5,092 posts
Posted 05 October 2017 - 02:22 PM
You have to use the symbol wizard ...
Have a look at this post ... http://softplan.com/...er-roof/?p=8039 ... this refers to trusses, but the principle is exactly the same.
#8 Guest_darin swanson_*
Posted 10 October 2017 - 11:47 AM
#9 Guest_Darin Swanson_*
Posted 10 October 2017 - 12:05 PM
I want to create a "artistic wall" with a first nations design.  ovoid and u-shapes used to create the wall.
