beam-broken...need help
38 replies to this topic
#1 Allen McDonnell
  • 957 posts
  • LocationIllinois
Posted 13 September 2017 - 09:10 AM
There is suppose to be a full length beam above my columns....any idea why it is being cut off towards the right side?
#2 Mark Petri
  • 1,512 posts
Posted 13 September 2017 - 09:15 AM
Did you check "fit to roof" or something?
#3 Allen McDonnell
  • 957 posts
  • LocationIllinois
Posted 13 September 2017 - 09:18 AM
No...on roof plan all walls are same color.
If i drop it down an 1/8" or more it will re-appear.  But that would be incorrect...all plates are same height on this one.
#4 Jason Bishop
Jason Bishop
  • 295 posts
It's a glitch. I have it happen periodically as well. As far as I know, there is no fix. Sometimes erasing the beams and redrawing them with a zero join tolerance will work.
Very frustrating.
#5 Allen McDonnell
  • 957 posts
  • LocationIllinois
Posted 13 September 2017 - 09:23 AM
Agree.......
#6 Rick Kingsbury
Rick Kingsbury
  • 170 posts
  • LocationSpearfish, SD
Posted 13 September 2017 - 09:35 AM
I was told by support that the beam will terminate if there is a roof over another roof.
I was not pleased by the answer as this situation happens quite often.
Hopefully there will be a fix in a future patch.
#7 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 13 September 2017 - 09:43 AM
It appears that the roof to the right is trimming off the beam where it would project through that roof. Please submit a ticket with the project so that we can take a better look and report the issue as necessary.
Thanks.
#8 Brad Graber
Brad Graber
  • 295 posts
Posted 13 September 2017 - 09:52 AM
Happens to me a lot as well.  I submitted it to tech a while back.  I know of no real cure for that happening.
#9 Allen McDonnell
  • 957 posts
  • LocationIllinois
Posted 13 September 2017 - 09:57 AM
Brent, the heel heights on the roof to right were different than the main roof (not sure why) but once i edited the edges of that roof to match the heel heights of main roof issue went away.   Thanks.
#10 Mark Petri
  • 1,512 posts
Posted 13 September 2017 - 10:47 AM
Have you tried a wall definition with only a beam? Wonder if that would work?? That is frustrating.
#11 Joseph Smith
  • 824 posts
Posted 29 September 2017 - 10:10 AM
FYI to all, this is a program glitch.  SP support has been aware for a long time now, hopefully we get a solution in the next update.  Use a solid like a cube to simulate the beam as a band-aid fix until they provide a fix.
#12 Joseph Smith
  • 824 posts
Posted 24 October 2017 - 03:14 PM
Still not fixed!  I created another ticket, pretty sure its my 3rd or 4th ticket for this problem.
#13 Brad Graber
Brad Graber
  • 295 posts
Posted 25 October 2017 - 06:32 AM
i have been having the same issues with that, and haven't found any work around to get it to behave itself.
#14 Joseph Smith
  • 824 posts
Posted 28 November 2017 - 08:57 AM
I just installed the patch 2018.4.3 this morning.  Perhaps they fixed this.  I've only been complaining about it since the release of 2018.
#15 Allen McDonnell
  • 957 posts
  • LocationIllinois
Posted 29 November 2017 - 07:35 AM
Joseph, your shake is upside down....that is something that i am tired of.  I have the same issue on numerous homes.
#16 Keith Almond
Posted 29 November 2017 - 08:33 AM
Apparently, that was fixed in the last update ... or at least it says it was in the notes to the patch ...
#17 Allen McDonnell
  • 957 posts
  • LocationIllinois
Posted 11 December 2017 - 10:13 AM
Yes....all good.  But i feel the overall look/texture of shake can be improved.  Keith's texture are far superior....horizontal siding, board and batton, metal roofting to name a few.
#18 Joseph Smith
  • 824 posts
Posted 11 December 2017 - 11:47 AM
To be clear the beam is NOT fixed and the hijacked shake problem described IS fixed.
#19 Allen McDonnell
  • 957 posts
  • LocationIllinois
Posted 11 December 2017 - 02:11 PM
Yes....you are correct
#20 Allen McDonnell
  • 957 posts
  • LocationIllinois
Posted 02 January 2018 - 01:40 PM
This has not been fixed yet.
