Elelvation Opening Mull
#1 Brian Berzinskis
Brian Berzinskis
  • 470 posts
  • LocationNew Jersey
Posted 22 September 2017 - 08:21 AM
When adding an elevation opening like a casement window into a drawing and then modifying the properties to have 3 sections, is there any way to then adjust the size of the mull between the sections?
I am looking to change it from looking like they are so close together to having like 4 inches between the sections.
Posted 22 September 2017 - 08:44 AM
The easiest way is probably to add them as three single windows and bring them together to form a unit opening. EDIT > UNIT OPENINGS will make it a single unit dimensionally. You can then give it a specific product code, and use it again and again.
#3 Brian Berzinskis
Brian Berzinskis
  • 470 posts
Posted 22 September 2017 - 09:24 AM
Is unit openings command only for plan drawings and then when generating elevations?
I should clarify that I am drawing my elevations and I have placed Elevation Openings from the Detail menu.
Posted 22 September 2017 - 10:01 AM
If you're only drawing the elevations, then just explode the window and adjust to suit.
