Cabinet names show after clean-up
#1 Paul James
Paul James
  • 251 posts
Posted 04 October 2017 - 06:07 PM
Maybe this should be a suggestion, but is there a way to keep cabinet names from turning off when cleaning up the cabinet run?
I'll have a cabinet run cleaned up and all connected, turn the show all names on. But if you explode the run to edit or move something and re- clean up, the names turn off- and you turn them on again, and again.
Is there anyway to keep the names on all the time no matter what?
#2 Paul James
Paul James
  • 251 posts
Posted 04 October 2017 - 06:13 PM
I might have found a solution to this. If you uncheck Join Cabinets, the cabinets still clean up and snap into place- but keep their names on- this looks to solve the problem, unless there's some other problem with not using Join Cabinets?
#3 Brent Hyndman
Brent Hyndman
  • 1,549 posts
Posted 06 October 2017 - 07:19 AM
That will likely work but you can also edit the individual cabinet instead of the run and select Show Name and then do a Repeat Edit Box to make that change to the other cabinets.
By editing the run and then exploding it, you should expect to lose the 'run' properties you set in the edit. Editing the individual cabinets may be the better option.
