Is there an easy way to figure out the total amount of wall area based on the wall covering I've chosen.
Can I have that displayed in the Room Finish Schedule?
Or is it only available through the use of SoftList?
Posted 09 October 2017 - 05:21 PM
John Wright
Architectural Technologist
(905)973-6244
Posted 10 October 2017 - 04:55 AM
If you go into Interior mode, you can right click on the wall covering and choose "Label", then click in the room to add a label that gives the wall covering area. I can't seem to find a way to add this to a room schedule though.
Posted 10 October 2017 - 06:35 AM
That works well. Thanks Philip.
Though it is the gross area without any opening subtractions. Is there a way to export the amounts that would be calculated in the formulas we create in SoftList... subtracting the openings and the like. I do a lot of renovation work and these numbers are something that I have to calculate after I get the job when a client wants different wall finishes....
John Wright
(905)973-6244
Posted 19 October 2017 - 11:15 AM
To get the information you want without generating a full SoftList report you can edit the wallcovering and go to the SoftList Tab. Select 'List materials' there and it will give you the quantity of paint for that particular room/polygon using the formula and coverage already set-up in SoftList which does account for the removal of the opening areas.
If you just want the areas without coverage and cost, the paint formula can be copied using the Add Companion Material button, give it a name like 'Paint Area', change the units to Sqft, remove the costs associated with it and remove the coverage factor.
SoftList Tab.png 16.04KB 1 downloads
Posted 20 October 2017 - 05:28 AM
Perfect perfect.
It would be great to see a softlist report developed for this sort of remodeling situation. Information created on a per room basis. Listed by area or whatever the pertinent quantity is. Mind you I guess that is something I would need to develop myself.
Bedroom
Floor Area
Perimeter
Baseboard lnft
Casing lnft
Crown molding lnft
Wall Paint ft2
Ceilng Paint ft2
Flooring ft2
Receptacles
Switches
Lights
I guess I have some homework to do.
It would also be great to be able to easily be able to insert that information as a live variable in a room note. I find for handling sub trades, and my own employees, having the items required on a room basis is a god send for being able to check off items as they are completed.
Any ideas for that?
John Wright
(905)973-6244
