I have been doing full fly arounds and they work quite well. Does anyone know how to do a partial animation...say only the left front around to right front of a 3D rendering? Sometimes I want to show only an area of the home that has been revised. Any help will be appreciated...thanks
3d animations
Posted 16 October 2017 - 09:32 AM
I would suggest taking a look at using the 'Add New Key Frame' option for creating the animation path.
Place the camera where you want to start the animation, select Camera- New Animation and select the '+' on the right side of the timeline to 'Add New Key Frame' at each camera location. Move the camera to the next location and select the Add New Key Frame button again. Repeat a few times until you are at the desired end location. When played again from the start, the camera will travel between the points to create a smooth motion. You can adjust the timeline and delete points or add points wherever necessary.
You can also take a look at the 3D Training- Animation Path tutorial for a more detailed explanation.
Posted 16 October 2017 - 11:59 AM
SoftPlan+ subscribers have the Training Video Library links on the Start page. Once you select the 3D Training, the Animation Path lesson is number 26 on the list.
For those who are not SoftPlan+ subscribers and do not already have the training DVD's, the training DVD's can be ordered online by logging in here: https://softplan.com...k&page_id=1041
Once you get used to the process of creating your own timeline you will have a lot better camera placement with the ability to move in close, back away and change planes.
