Two Models for Elevation Generation
7 replies to this topic
#1 Brian Berzinskis
Brian Berzinskis
  • 470 posts
  • LocationNew Jersey
Posted 29 March 2015 - 06:40 PM
Is it possible to create a second Model for Generating Elevations? Because I do a lot of detached garages or pool cabanas and I have to always remove all of my building from the Model to make the drawings for the garage.
#2 Yvon Gonthier
Posted 30 March 2015 - 07:02 AM
I would say that you could use cross-section lines to create some of you elevations. This way, you can select a view between the house and garage and also control the length of the view your generating.
#3 D M
D M
  • 402 posts
  • Location..
Posted 09 April 2015 - 12:31 PM
You could make two separate Models, one for your house and one for the outbuilding, ..
I think then, that both can be incorporated into a 'Neighborhood' where you can try out different display or render options.
Posted 09 April 2015 - 12:57 PM
Thought I'd already replied to this ... Damn I'm getting old.
I agree with Douglas. Neighborhood is the way to go that way, the buildings can be completely separate and added to a single site plan. That way they keep all their own finishes etc. The only one I've done was flat, but I think you can set building elevations separately to adjust heights etc.
#5 Yvon Gonthier
Posted 09 April 2015 - 02:04 PM
You did, it was under the topic "Site plan". But you're still getting old ;o)
#6 Brian Berzinskis
Brian Berzinskis
  • 470 posts
Posted 10 April 2015 - 03:39 PM
Thanks guys. I will try out the neighborhood. Never used it before but sounds like it should do what I ask.
#7 admin
admin
    Administrator
  • Administrators
  • 88 posts
Posted 10 April 2015 - 04:09 PM
Try placing the house and garage on separate building options.
Posted 10 April 2015 - 06:10 PM
Thanks Yvon, between you and my wife, I think I'm getting an inferiority complex. Although my wife would say it's not a complex ....
  • Yvon Gonthier likes this
