Dear Softplan, I know this is not a big issue, and it should be really easy to fix, but PLEASE can you put the mortar joint UNDER the masonry, not on top of it!
Mortar Joints in Masonry
#1
Posted 20 October 2017 - 08:25 AM
Posted 20 October 2017 - 10:22 AM
Yes, I'm talking about section details specifically. Exact masonry coursing shows the mortar at the top ... Masonry should start on a mortar joint and end without one ...
2017.10.20_12h19m35s_001.png 23.34KB 2 downloads
Posted 23 October 2017 - 02:20 PM
Since we are talking about blocks, have anyone ever noticed that the 12 inch block is an 8" and a 4" side by side? Look at the horizontal block in the 3D. Not sure what's going on with the vertical blocks.
Block Wall.pdf 98.72KB 36 downloads
#7
Posted 23 October 2017 - 03:09 PM
No. it isn't ... It's just the standard texture that wraps onto all faces. It's the same with ALL materials and textures.
Posted 23 October 2017 - 08:23 PM
So to follow up with a question and solution Keith you should be able to adjust material and change the paint patter to 150% and it will fix it? However I guess the 16" block will then become 24"
#9
Posted 24 October 2017 - 06:22 AM
If you change the paint pattern to 150% then the vertical coursing on ALL the faces will become 12" ....
The paint textures do not understand TOP, BOTTOM, LEFT, RIGHT or UP and DOWN. All they are, are JPG textures applied to a face. regardless of where that face is. EVERY face of a single 3D object has the texture applied.
Also depending on how the seamless JPG is designed depends on where the edges are, so as Paul stated, sometimes the joints are on the edges. I don't think that we should expect miracles from the surface applied textures, although it would be nice to be able to adjust the SEED POINT of the texture (as opposed to the actual SEED POINT of the paint), so we can control the look of the texture, especially when vertical or horizontal lines are supposed to line up and don't - As is typical with board and batten siding in gables.
Posted 25 October 2017 - 09:54 AM
Agreed on that note too Keith. We ought to have much more control over textures and patterns in the way materials work. There are so many little things within this discussion thread that would be huge improvements for modeling and rendering our projects in SP. In competing software you can select a texture and have all other textures align to that one wall/surface. In others, you can choose orientation, scale, position (seed point), etc. The rotate feature in SP is a pretty elementary feature, and often not much help.
#11
Posted 25 October 2017 - 12:35 PM
We should be able to manipulate JPG textures in the same way we can manipulate paint lines ... SIZE %, OFFSET (Vertical & Horizontal) and ROTATE ANGLE.
Posted 26 October 2017 - 03:01 PM
Thank You Brent.
Posted 26 October 2017 - 06:24 PM
