Wall lists save to system
#1 Chad Lechleitner
Chad Lechleitner
  • 29 posts
Posted 02 November 2017 - 10:13 AM
In a current drawing I have made some new walls.  How do I save them to the system walls so whenever I create a new drawing I can use these new walls by default.  Currently I export a floor plan from a old drawing, erase the floor plan and start a new with the old drawing wall lists.
Chad
Posted 02 November 2017 - 10:33 AM
Go to:
FILE > DRAWING OPTIONS > DRAWING OPTIONS > DEFINE WALL > IMPORT/EXPORT and under the Export column, CLICK (or SHIFT-CLICK or CTRL-CLICK) all the files that you want to export, and then click EXPORT TO FILE.
Then go to:
FILE > SYSTEM OPTIONS > SYSTEM OPTIONS > DEFINE WALL > IMPORT/EXPORT and under the Import column, Click File then LOAD FILE - Select the file you just saved, and then CLICK (or SHIFT-CLICK or CTRL-CLICK) all the files that you want to import, and then click IMPORT.
You can obviously do ALL walls or just a few walls at the same time.
#3 Chad Lechleitner
Chad Lechleitner
  • 29 posts
Posted 02 November 2017 - 10:43 AM
Keith,
Chad
